Thread: Crunching Noise
    Scotland
    Default Crunching Noise
    Hi all new to the site and novice at repairs.
    I recently decided to repair my own car (same as most people money tight nowadays) . So i replaced all brake discs and pads and then began to get a bug for it. So changed air, pollen and oil filters and oil change. So next i noticed some other things need doing so would like some help from you guys if possible.
    I have a vectra 04 plate just the standard 1.8. I have a noise coming from the front when going over speed bumps at anything faster than edging up and down. I have read a few posts over past few days about possible issues from drop links and ARB bushes so i plan to get under at weekend and look. However i noticed movment on the front O/S wheel when holding in 3 oclock and 9 oclock and shaking and seen a few suggestions for this also.
    If anyone could help me by directing me on what to look at when under to establish which of all possible culprits would be causing the issues as i really cannot afford to replace everything at this point in time.
    So i believe:
    Crunching could be : springs, ARB bushes, Drop Links
    Movement could be : bearings (i beleive complete unit with abs would be needed i may be wrong), track rod end.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The crunching is probably drop links or ARB bushes as you say. Not expensive and are relatively easy to change.
    Scotland
    Default Thanks
    thank you Ste for the reply.
    Was wondering if anyone has a guide/pictures as to what to look at and what it should look like so i can identify what needs replaced from the parts i mentioned.
    I.e how to tell if drop link is knackered or ARB bush is knackered.
    Also how to tell if its the track rod end or the bearings ont he wheel movements thing.
    Please excuse any stupid comments i make new to the repair thing
    Scotland
    Default Big Thanks
    Guys finally got round to doing the droplinks and arb bushes today.
    thanks to the How 2 it was straight forward to do.
    The dreaded crunch has gone.
    Couple pointers for anyone.
    10mm ring spanner worked better than the E12 torx spanner i bought (due to restricted space could not get the torx on all the time)
    I also used a very long bar and E12 torx socket for the front torx screws on bushes was much easier.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Glad you got it sorted. I need to do mine, as they are wearing a bit now.
    Regular Member old cruiser's Avatar
    slough
    Result there mate, but the question I suppose is ; what was the cause of the crunching, the droplinks or ARB Bushes, I suspect it was more the bushes?
    Cheers Pete
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    I need to do mine too. Is there a how-to? I shall have a look around.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Scotland
    Default Correct
    It was the bushes in particular the front offside .I had both front ends up on axle stands and the drop links off. The minute i touched the loose anti roll bar on the driver side there was that dreaded noise.
    @GsiFan mate make sure you set sometime aside as those bushes can take forever due to lack of space (get a 10mm ring spanner instead of paying for an E12 like i did)
    Other than that its a very simple process
    21 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Thank you, Decker. I have at least one 10mm ring spanner already, so that suits me fine.
    Paul
  1. Crunching noise on bumps
    By crazychemist76 in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2013, 09:11
  2. Crunching noise +ARB bushes
    By FrenchConnection67 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th December 2011, 00:43
  3. crunching and knocking noise
    By 1978spn in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2010, 16:56
  4. Crunching Noise when Turning
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2010, 18:46
  5. Crunching noise
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:55
vectra with crunching noise drivers side
