Thread: 2.2DTI SRI Exhaust Problem
    Regular Member Dazzy2006's Avatar
    Notts
    Default 2.2DTI SRI Exhaust Problem
    This morning i was driving down the road and heard a scraping noise so had a look and the bottom of the backbox was dragging on the floor
    I had to pull it off but when i looked at the exhaust it still looks complete and doesnt seem any louder
    i'm baffled - are the backboxes double skinned or something?
    Nottinghamshire
    Quote Originally Posted by Dazzy2006 View Post
    Yes, they are double-skinned. The car will be a tiny bit noisier with only 1 skin. The bottom half of the outer skin rusts through around the seam and then falls off.
    Mine did the same about a year and a half ago. I pulled the bit that had fall off the same as you in order to get home (with bad flu, in the pouring rain, in my suit ) then later neatened up the jagged edge and checked for holes. Luckily, there weren't any holes and it has been running like that every since including passing 2 MOT's without comment.
    Notts
    Thanks james u have put my mind at rest - i'll probably replace it before its mot depending on how expensive the backbox is
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The outer skin on mine came adrift too. I had to remove it to stop it dragging too. It's been like that for about 6 months at least now without further issue.
    Oct 2009
    Swindon
    Back boxes are around £250.....around £170 with Trade Club
    Nottinghamshire
    Quote Originally Posted by damian s View Post
    They're around £100 from a exhaust centre or motor factor.
    As mine has proved, the back boxes can run for ages with just a single skin left as long as the departing second skin didn't rip the seam apart.
    I'm just keep a close eye on the remaining skin as it's starting to go rusty on the bottom and around the seam after nearly 2 years and it'll obviously need a new backbox when it does spring a hole!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Go onto ebay, you can get a Sportex backbox for the DTi of 120 quid
    Notts
    Cheers for the advice lads - at those prices i'll leave it as it is until i either get pulled, it fails an mot or the rest of it drops off then i'll probably go for the sportex one off ebay
  1. MaF problem. 2.2dti
    By fuzzyllogik in forum Engine & Drivetrain
    Last Post: 14th July 2012, 15:12
  2. 2.2DTI Problem
    By Dazzy2006 in forum Engine & Drivetrain
    Last Post: 13th January 2010, 20:50
  3. 2.2dti and 2.2 direct exhaust
    By damian s in forum Engine & Drivetrain
    Last Post: 27th December 2009, 19:30
  4. sri 2.2dti stainless exhaust
    By eddy in forum Diesel Engine related
    Last Post: 14th December 2009, 14:59
  5. Vectra B2 2.2DTi Exhaust
    By Celes in forum Vectra C / Signum Troubleshooting
    Last Post: 4th October 2008, 23:40
