Thread: Blower Motor Fault...With a Difference!
    Regular Member cphaza's Avatar
    Hertfordshire
    Default Blower Motor Fault...With a Difference!
    Bit of a funny one here. Heater motor blew (and resistor) recentley, full of water. Blagged another one of each from the scrappers for £30 and fitted up. However, now I have speeds 1 and 4 only, and it wont turn off! By that i mean that when you switch down from speed 4 (which works normally) every other setting just blows at speed 1, including when you turn the begger off!
    I'm guessing its a dodgey switch pannel, but just seems a bit of a coincidence for them both to go at the same time so figured i'd throw it up here to see if anyone has any bright ideas!
    Chris
    Hertfordshire
    Sorry, not sure how i managed to post this twice, t'ut internet playing up! Can admin remove this thread, ta.
    Hertfordshire
    6 Post(s)
    Use the report post button to flag it up to a moderator.
    Hertfordshire
    its ok, they deleted the other one (somehow started two threads!) Was more of a bump for info on the problem. Got me a bit foxed!
    Hertfordshire
    anyone any ideas? Dont have another switch pannel to try at the moment as the mrs is away but with the other vec
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have a look at the wiring diagram
    http://www.vectra-c.com/forum/upload...010/Heater.JPG
    and check the voltages into the resistor pack. Position one will put power through all 3 resistors and position 3 only through one resistor. Position 4 operates the relay K5.
    Should be fairly easy to see if it is the switch pack that is defective.
    If it is the switch panel, I would have thought that it could be repaired without too much trouble - maybe just dirty contacts?
    Hertfordshire
    cheers mate, havent studied a wiring diagram (must bite the bullet and get a haynes - they are good for some things!) but will do so tomorow. the fact that its always on when ignition is live makes me think switch, or relay of course.
  1. Changing the blower motor?
    By kangakev in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2014, 19:11
  2. Blower Motor?
    By steve533 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2012, 22:00
  3. Vec C Blower Motor
    Last Post: 31st December 2010, 17:24
  4. help heater blower motor
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 01:27
  5. Blower motor
    By Butler in forum Bodywork & Interior
    Last Post: 13th January 2009, 09:47
Www.vectra 2.0 wiring diagram
vauxhall vectra c wiring diagram
vauxhall vectra electrical scheme
vectra c sähkökuvat
