Results 1 to 10 of 13
Thread: Ashtray and cigarette socket
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default Ashtray and cigarette socket
    Hi,
    my rear ashtray is wedged shut. Is it easy to remove/fix? If so how?
    Also the rear cigarette socket isn't working - any ideas?
    Regards
    Ben
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    Sounds an obvious question, but you have pushed down on the ashtray lid haven't you, it should then pop up.
    Apologies if this isn't what you meant...don't wish to imply any denseness on anyones behalf.
    Failing this, remove the gearstick chrome effect surround and lift up the gaiter, that's about as much access that you will get to the underside of the ashtray from the front without removing the centre armrest etc.
    You could try pulling out the oddments tray above the ashtray to see if access from behind the ashtray is any better for you. (The odd ments tray is just push-clipped into place so just needs pulling out)
    Sep 2009
    Stratford-upon-Avon
    Hi Ben, Mine was like this when i first got the car, I gave it thump and it popped open, then i fitted it properly, its fine now!
    That is my normal approach to stuff that breaks in the car - thump it, however, last night i was fitting my auto dim rear view mirror and couldnt get it to slide on, so gave it thump....
    ....have just got off the phone to autoglass
    Quote Originally Posted by Robsey View Post
    OP is asking about the REAR ashtray
    Regarding the rear accessory socket, have you checked the relevant fuse in the boot fuse box?
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    Ooops, yes so he is...
    The trim panels on the rear ashtray / armrest assembly just unclip.
    Use a plastic wedge, body filler spatular or plastic ruler to get between the plastic trims and the ashtray surround.
    Don't use metal (such as a knife) as you can easily scratch the plastic panels.
    Everything is just clipped together.
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    day off tomorrow. i'll check the fuses (any idea which one?) and have a thump(!) and a go with a spatula!!
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    Fuse number 17 in the rear fuse panel (left side of boot).
    Rated at 7.5 amps....brown fuse I think!!
    And / Or Fuse 22 at the end of the dash - 30 amps
    When you dismantle the rear section...if the socket is not connected up, then look for a connector with three wires, near the hand-brake.
    Wire colours are , brown (earth), black (ign live) and grey/yellow (illumination)
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    well no fuse in 17 and looks like spring missing from the ashtray? cannot see an other reson for it not opening
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Quote Originally Posted by benwalters82 View Post
    Can you post a pic of the rear of the ashtray, I may have the bit you require but really hard to describe how it fits
    Regular Member IrishWhiskeyChaser's Avatar
    Jan 2010
    Ireland
    I have the same issue with the rear ash tray the spring part is disconnected and it does not work. easy to open it though. Haven't checked if the plug works yet as I have not dreamt up a use for it yet
  1. cigarette socket
    By a6lns in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2011, 17:08
  2. front ashtray/cigarette lighter suround
    By shb1988 in forum Styling
    Last Post: 7th January 2011, 11:51
  3. 12v cigarette socket .......
    By Houstie in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2007, 15:51
vectra c illuminated ashtray
