Results 1 to 3 of 3
Thread: dmf question?
    Regular Member DannyBoyDti's Avatar
    Jan 2010
    Bradford
    Arrow dmf question?
    Does any one know how to check the dmf for wear?
    im going to change my clutch as its slipping when i drop it down a gear and floor it, so was wondering if i can get away with changing the clutch for now? i know you have to change all 4 pieces but cant afford 500 squid til end of march or doesn't it matter as i will be changing all parts then??
    Jan 2010
    Bradford
    sorry 2.0 dti sxi july 02
    london
    Dmf should rotate left to right between 15 and 30mm with some resistance. Also hold at 12 and 6 o clock postion and you should get about 1-2mm movement.
    These are tolerances from another manufacturer, but probably all roughly the same.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
