Results 1 to 2 of 2
Thread: vectra c 1.8 2003 aux belt change help
    Jan 2010
    croston lancashire
    Default vectra c 1.8 2003 aux belt change help
    hi there im trying to put a new aux belt on and cant get it on its the correct belt but is a tad too tight cause its new i pushed the tensioner but its still little tight is there a way to get this dam thing on ? ive put old one back on for now .
    May 2008
    Tyneside
    Are you sure the new belt is correct, the length is printed on the outside. I was supplied with the wrong belt, the new belt was 10mm shorter when I checked the markings. HTH
  1. 2003 Vectra C 1.8 Petrol Timing Belt Noise
    By chrisjt31 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:21
  2. 2003 vectra c 1.8 ls Timing Belt/water pump
    By Tank988 in forum Engine & Drivetrain
    Last Post: 19th January 2012, 18:42
  3. 2003 vectra c 1.8 ls Timing Belt
    Last Post: 3rd November 2011, 13:09
  4. 2003 vectra c ls 1.8 Timing Belt
    By Tank988 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 00:58
  5. 2003 vectra c ls 1.8 Timing Belt
    Last Post: 17th March 2011, 15:59
