Results 1 to 10 of 21
Thread: bent seized bolt - bottom of rear shock
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Angry bent seized bolt - bottom of rear shock
    am in the process of changing my rear shocks.. left hand side was easy.. the right hand (drivers) side has turned into a right pig of a job...
    I have loosened the top bot which is but the bottom bolt was tough all the way up to the point where it decided it will not come out anymore.. its up on an axle stand not a lift so their is no room for a breaker bar.. although i do have one.. the E20 hex/torx head on the bolt is now starting to wear down.. I have sprayed penetrating oil over it and even tried straightening it (with a persuader)..
    This thing is not budging... Any tips...?
    Regular Member Jezzy's Avatar
    S.E
    Cut it off with an angle grinder and replace it?
    Jun 2009
    South Coast
    am tempted to cut it off, i can see over an inch of thread so far, but do not want to end up with the remainder of the bolt stuck in the car leaving me without a way to get it out...
    I think I am going to have to limp it up to garage to get some machanics on it who will obviously have more tools than me and will have come across this kind of thing before.. Will just buy a new bolt from vx first...
    If I cut it off and cannot get the rest of the bolt out it will mean i will then have to drive it a garage anyway but with a shock missing.. has anybody ever done that, will it naff my car up...?
    WGAF#5
    tighten it up again and loosen ...lubing while tightening and loosening
    = repeat process it will eventually give
    Jun 2009
    South Coast
    lol tried that already.. it is stuck fast.. will not go either way and the more i try the more the head is starting to round off.. I have ordered a new bolt from vx and have it booked into a garage on Monday (unless i managed to remove it this weekend with the help of my enthusiastic neighbour). Its been soaking in penetrating oil overnight, so fingers crossed it may have some give by friday or saturday..
    Mileage : 000
    Have you tried bashing it ( as in length ways, not side to side) This might free it off a bit.
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    Try a bit of heat m8 a blowlamp will do
    Oct 2009
    Swindon
    it maybe that the bolt is out of the thread but the pressure from the spring and shock pulling down on the bolt mean you are unable to remove it from the start unthreading section of the hole....I found this when removing my rear shocks, I dropped the spring out first which made it much easier.
    Northampton, UK
    Have you tried taking the weight of the arm etc of the bottom of the shock, by using a jack under the shock?
    Oct 2009
    Swindon
    Thats what I was trying to say Mr Hudson.......just went the long way around it! lol
  1. Went for alignment - seized bolt!
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 10:53
  2. Seized rear caliper, is this the right one?
    By yysnet in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 10:12
  3. rear callipers seized! help.
    By tonyblade in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 13:00
  4. Seized rear calipers or not
    By stitchi1973 in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2009, 19:45
  5. Rear Brake caliper seized?
    By Ian T in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2007, 11:49
vectra c rear shocks bottom bolt siezed
