Results 1 to 3 of 3
Thread: CD30 and TID
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default CD30 and TID
    Hi guys. I'm after some advice about changing my TID screen for a GID screen.
    As the title says, I have a CD30. I've searched the forum and found some info, but just want to check my understanding.
    If I can source a GID (which I guess will need to have been Tech 2'd from the original car) is it just the case of a straight swap for the TID and then Tech 2 to get the BC functions to work?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Need to join 2 wires together they can be crimped or spliced ans joined one's power other is earth,then tech2 to pair it with your CD30 you might not need BC actiavted as it might all ready be done but best ask anyway
    Pins 5 and 3 joined together and 1 and 2 on 32 pin plug
    Irmscher Insignia CDTI 130
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Dependent upon car wiring, as said above, you should have 2 red and 2 black.
    If you only have one of each, then you will need to link in extra wires as described above.
    Ensure the GID is Tech 2 divorced from donor car, then it can be fitted and tech 2 married / programmed to yours.
    Hopefully job done!!!
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. Cd30 & bid
    By KyleSxi in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 15:50
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
