Thread: heater fault on vectra c
    WEST MIDS
    Default heater fault on vectra c
    hiya im new to this site i hope some one can help me out ive just bought the vectra with this problem ive changed the resister and the control panel twice to be sure the new ones werent at fault the heater only works on setting 4 ive ran out of ideas now as i was told these were the 2 most common i hope someone as the answer for me thanx daron
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    normaly its the resistor or fans can sieze up
    Regular Member Dazzy2006's Avatar
    Notts
    - usually if the fan begins to seize it blows the fuse.
    Does the fan sqeak and make funny noises when u 1st turn it on?
    Have u tried taking the pollen filter out and spinning the fan by hand?
    You might need a new motor
    Northampton
    http://www.vectra-c.com/forum/showthread.php?t=99565
    similar fault to what i have? but have not got round to fixin it
    slough
    hi, if you take out your glove box and look up under the dash the side nearest the wing of the car you will see a blue small relay change it and i think you will be plesantly suprised and you will like hippo`s as much as i do.......
    WEST MIDS
    thanx guys i will try changeing the blue relay fingers crossed ps ive taken the pollen filter out motor spun freely no noise either when you switch on no 4, is there only the one blue relay under the glove box thanx again daron will let you know how i get on
    WEST MIDS
    me again also the chap i bought the vectra off says the car as been serviced but only one stamp in the book asked vaux they said they couldnt help me to trace where the car had been done any ideas ps the car is a vaux vectra 2-0 cdti 2003 elegance model thanx again daron
    Northampton
    did you get round to sorting this sneady?
  1. 2002 52 vectra C GSi Heater fault
    By AOL in forum Vectra C / Signum Troubleshooting
    Last Post: 1st February 2010, 23:36
  2. heater fault ?
    By s9aln in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2008, 19:17
  3. 2002 52 vectra C GSi Heater fault
    Last Post: 29th December 2007, 17:02
  4. Heater Fault
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2005, 13:49
small blue relay in glovebox vectra c
