Thread: Tailgate sidelight problem
    Jan 2010
    Smoke on Stench
    Default Tailgate sidelight problem
    I have a Vectra C estate 2006.
    The problem is the sidelight in the tailgate was not working and I got the check rear bulb warning.
    I changed the bulb and it still doesn't work and swapped the other sidelight bulb which is working and it stops working as soon as I twist it in.
    There is power going to this light cluster as the reverse light does work.
    Gonna strip it down tomorrow and take a good look.
    Anyone had anything like this before ??? I've done a search and nothing is showing up.
    Steeley7
    PRESTON
    Hey steeley, i had similar on my estate, nsr bulb wasnt working, got dash warning, so replaced with new bulb and it still didnt work. Noticed the contacts on the bulb holder were dirty, so cleaned them, bent them a little to improve the connection and it works fine now,
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by barney490 View Post
    get loads in with dirty connections quick clean both parts then fine.
    Jan 2010
    Smoke on Stench
    Cheers will give it a full over haul today...
    Regular Member dragonuk2000's Avatar
    Jan 2010
    Rossendale
    This problem isnt only confined to the estate my near side tail light would only work if it was on-screwed on my Hachback so i did what people on here said cleaned and repositioned the contacts and hey presto no more annoying 'bulb out' warning easy fix!
    Jan 2010
    Smoke on Stench
    just gone out to clean them up and I can hear a quiet clicking noise from this cluster not sure what this is, it sounds like an indicator clicking noise.
    It started snowing on me so I'll have another go tomorrow.
    Steeley7
    Jan 2010
    Smoke on Stench
    Just been out with the contact cleaner and the multi meter. The problem is I only have 6 volts on the sidelight but the reverse and fog is 12.
    This is the offside tailgate cluster.
    Everything else is okay and I have tried swapping bulbs about.
    Any ideas where to start ???
    Steeley7
    PRESTON
    hey steeley, as i understand it, all the bulbs on the rear are single filament, 12volt 21 watt and the car its self reduces the voltage to allow the sidelight to be dimmer as it uses the 21 watt bulb. Are all the sidelights producing 6 volts at the contact? if so this could be correct. The outers are side and brake lights and the car will increase the voltage to 12volts to these, when the brake is applied.
    Jan 2010
    Smoke on Stench
    confused
    Yep the voltage has been reduced... but at the plug it is showing 6.6 ish volts on the one that doesnt light. The other side that is working is showing around 4.5 volts.
    I have tested the circuit between the plug and the bulb holder which is fine but no voltage is getting through the plug connection??
    Confused.... gonna have to take the light cluster out of the car to see whats going on !!!
    Steeley7
  1. Tailgate problem
    By cendoubleu in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2013, 22:43
  2. 3.2 drivers sidelight problem
    By chaz851 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2011, 17:49
  3. Help! Sidelight Problem
    By JDX-SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2010, 22:56
  4. Vec C Facelift Sidelight Socket Problem
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2009, 10:06
  5. tailgate problem
    By victorM in forum Bodywork & Interior
    Last Post: 10th August 2009, 22:07
