Thread: ARB bushes
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default ARB bushes
    After being sent the wrong bushes (finding out the hard way), the new bushes were far smaller in size than the ones previously fitted. I emailed eurocar parts asking for a refund, they said they'll happily send out the correct bushes FOC (I think!). The guy emailed me back today saying "There's a choice of 24.2mm or 25.2 mm bushes on this model, Unfortunately the chassis number doesn't identify which is fitted, so you'll need to check the size on your car. It should be stamped on the bush. " I'm sure the difference in size was more than 10mm, but maybe i'm wrong. Anyway, I don't suppose anyone would know which are the correct ones? It's a 52 plate LS 2.2 petrol non direct. Cheers.
    Regular Member Jezzy's Avatar
    S.E
    I think there actually 3 different sizes...but yours won't be the largest size, on account of your engine and the fact it's an LS.
    S.E
    Correction - there are 3 sizes of anti roll bars, but the smaller size bush fits the smallest 2 bars. You'll need the 24mm bush (what ECP have called the 24.2).
    Sep 2009
    Warrington
    I'm assuming the 24mm is the width of the bush? I'll just go measure which ones i've been sent to make sure i'm not getting the same ones sent back.
    S.E
    You might have difficulty getting an accurate reading from the bush, given the small difference in sizes. The measurement is actually for the anti roll bar itself, and I think the bush is supposed to stretch slightly when you fit it. As you're buying from ECP and not from Vauxhall, I don't suppose they have GM part numbers - if they did I could check which ones you've been sent.
    Sep 2009
    Warrington
    Just checked, there's no GM part numbers on the boxes. Measured up the bushes, 40mm long 31mm wide and the hole is 16mm with the gap closed if you get what I mean. IIRC the anti roll bar was alot wider than 16mm!
    Sep 2009
    Warrington
    Could anyone confirm the right size bushes i'm in need of, as I really don't fancy all that carry on just for a check, and I can't do it until the weekend anyway!
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    take it down your local car spares and match it like for like if you have one off the car already
    Sep 2009
    Warrington
    Quote Originally Posted by davidjameswest View Post
    That's just it, I don't have one of the car, I couldn't take it off and just leave it without a bush, so had to put the old one back on as the new ones was the wrong size Figured someone might know off here!
    S.E
    You need the 24mm ones.
  1. A.R.B Bushes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2011, 21:39
  2. arb bushes
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 09:51
  3. ARB bushes
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 00:29
  4. arb bushes
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 14:54
  5. Replies: 5
    Last Post: 21st March 2010, 12:34
