Results 1 to 10 of 13
Thread: Can this cause more damage...
    Regular Member PAULMAC77's Avatar
    warrington
    Default Can this cause more damage...
    If the swirl rail has come off your car, can this cause any more damage to the car if you carry on driving it like this? as i dont have the £650 to fix it right at this moment in time.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Would it not be worth you doing the tap washer fix in the meantime, just out of precaution?
    Yep, there is a £4.76ish fix on here in the how to section iirc.
    Regular Member Jezzy's Avatar
    S.E
    Anyone have a picture of this swirl bar (in situ on the engine)? I've always wondered what you diesel drivers are referring to when you talk about it.
    Regular Member badback's Avatar
    Runcorn
    I did mine yesterday using the quick fix, what does the swirl bar actually do? is it supposed to move when the engine is running or only at certain times? thx.
    It opens and shuts the 4 swirl valves that help to improve performance at certain rpm
    http://en.wikipedia.org/wiki/Variabl...ntake_manifold
    cheap fix
    http://www.vectra-c.com/forum/showth...ht=swirl+valve
    Runcorn
    Thanks Big Sig.
    warrington
    i aint that good to do a repair like that haha, i gues il just leave it till i got the pennies to fix it properly, so does anyone know if it will actually damage the engine or anything being broke off?
    Apr 2009
    stockton-on-tees
    id also like to no about this how do u no it is broken? and do you get them on 2.0dti's?
    May 2007
    GLASGOW
    am on the same boat as u mate, running with it broken but cant afford to fix it esp when car still runs fine in the 1st place. dont think i would be able to fix mine, theres a business idea for someone on here lol mobile swirl bar fixer!! u would certainly have plenty of work by the sounds of it
  1. Damage.
    By vaughaney68 in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2012, 20:34
  2. EGR cause more damage?????
    By lloyd_456 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2010, 23:55
  3. What's the damage?
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2008, 20:41
  4. Damage
    By Dodger in forum Comedy & Humour
    Last Post: 1st March 2008, 13:13
