Thread: 18" Snowflake tyre pressures
    Leeds
    Default 18" Snowflake tyre pressures
    Hi - just picked myself up a set of 18" Snowflakes with Conti's on. Can anyone tell me what the ideal tyre pressures should be? Car is an 08' plate CDTi SRI 150 - never more than 2 adults and 1 baby on board
    Also I bought these knowing full well that they might need refurbishing and on them they have strange looking bubbling on the rims - it's very small bubbles and the paintwork has not cracked / split or exposes the metal rim underneath anywhere at all.
    I'm wondering what this can be? Never seen anything like this before, as far as I'm aware the wheels came of a 2008 VXR Astra so doesn't look like they've been poorly refurbished in the past - but I could be wrong.
    Thanks - J.
    Leeds
    Think I may have found a guide - in the handbook for the saloon with 225/45/18 it recommends 32psi all round.
    Now the wheels I have are from a VXR Astra which have 225/40/18, the Vectra VXR has 235/40/18 as standard.
    So will give 32psi a go and see how it feels.
    As for the little dimples on the paintwork on the rims ... anyone any ideas?
    Leeds
    Right, well I'm happy with my Snowflakes for now ... the ride feels pretty much the same as it did with standard wheels on. What do people normally do with regards to the speedo being slightly out - anything?
    Norwich
    Trim : SXi
    Engine : 2.2
    I run exactly same size and go with 38psi all round. The bigger the tyre and smaller profile the higher the psi is. I run the gf megane with 15" on 32psi
    The speedo should not be that far out as the bigger the wheel gets the lower the profile of the tyre so the overall diameter remains almost the same
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    My 08' Vec manual states 225/45-18 with upto 3 in car 33 psi and fully loaded 36 psi. run mine at 33 psi, 2 adults and 2 children under 3.
  1. tyre pressures on 19 " snowflakes??
    By matrix1979 in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2012, 00:59
  2. Tyre pressures 1.9 cdti 120 16"
    By mcpitman in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2011, 02:11
  3. 18" tyre wear and pressures
    By mrkebab in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2007, 09:25
  4. Tyre Pressures for 19" Wheels
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2007, 16:25
  5. 19" Tyre Pressures?
    By JP7 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2006, 22:12
vauxhall snowflakes 19 tyre pressure
