Thread: Engine management light
    Regular Member beethamwest's Avatar
    Jul 2009
    Liverpool
    Default Engine management light
    When i irst got the car and put new wheels on, the brakes needed replacing. Now i get new wheels again and the engine management light is on.
    Spooky
    ANyway what number of things could it be. Vaux book says something to do with excessive emmisions? The car has been sat in the cold and not moved from 21 jan to 31 jan so could that be anything to do with it
    Sorry im not clued up about engines at all so help would be kindly appreciated
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    There is a method that works on some cars for reading "some" of the fault codes
    If you hold the brake pedal and the accelerator pedal down and turn ignition to 2 the managemant light should bleep the codes to you
    codes are 4 digits long like 0700 etc.
    for 0 it will flash 10 times, for 5 it will flash 5, 4 will be 4 etc
    inbetween each digit it will have a short pause, and inbetween each code it will have a longer pause
    This does not work for every car and nor does it pick up every fault
    You may have to have it plugged in at a garage if it doesn't go by its self
    Worcs/Staffs/Westmids (ish)
    You've had new wheels on it? again? (sorry I dont entirely understand)
    Who changed the wheels? (yes im suspecting foul play!)
    Your exhaust hasn't suddenly and mysteriously developed a screw driver sized hole, or the lambda wires broken very neatly has it?
    Jul 2009
    Liverpool
    Quote Originally Posted by Birchy63 View Post
    I've gone from the 17'' to 18''
    Same company sold and fitted them yes and if you ask me took too long to fit 4 wheels.
    Swapping my brake pads for some worn down ones could have been possible first time but i will never have any proof
    Jul 2009
    Liverpool
    Just done the free check way using the pedals and ignition.
    10 beeps were followed by a pause.
    10 beeps again followed by a pause
    3 and then
    6
    from what i have read that equals 0036
    following this the engine light stayed illuminated so i assume there is one fault
    The thing i don't understand is on the guide here - http://www.vectra-c.com/forum/showthread.php?t=19442
    has letters like P, C etc at the beginning. I assume mine is P.
    0036 is HO2S Heater Control C ircuit (Bank 1 Sensor 2)
    Anything to worry about?
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
