hi all not sure this is in the right section, when i collected my car from garage i stripped the damaged area inner wing was fine just cosmetic really, you have to take side skirts off to remove wings which is really simple 5 min job a side, the inner wings are slightly different once slam panel fitted you have to drill one hole for headlight clip that pushes through slam panel into inner wing I have upload a pic off o/s you can see the black clip that fits through slam panel and through hole in wing spent some lining up the wing luckily my dad has a vectra c so can look at his through the build just waiting to get parts have front bumper but that will go on last
