Thread: stuck calliper
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Default stuck calliper
    so i have found out that the rear drivers side calliper has seemed to have got stuck on so were do i go from here,what parts would i need to replace.
    do i change the complete lot calliper,pads,disc.
    do vx sell the calipers.....
    was getting a mate to do it but hes thrown his back out so it looks like it's going to be a garage now that does it but i dont wanna be getting ripped off,ya know with all there mmmm,aahhhhhing £££££££ so what price range would i be looking at...
    thanx in advance
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Quote Originally Posted by andy76 View Post
    thanx in advance
    I would imagine that all you need to do is take the calipers off and clean up /copperslip the sliders, these are the posts that attach the caliper to the hub assembly,and as long as these are not rusted all you need to buy is a set of pads.
    Cheers Ian
    May 2008
    Tyneside
    Probably the caliper piston seized. Just replaced mine last weekend, £70 for a reconditioned caliper from an independant. Over £100 reconditioned at Vauxhall and £150 for a new caliper. If pads are OK thickness wise no need to replace. You can buy the seals for rear calipers for £30 from Biggred but a fiddley job and in my experience not worth the cost and effort.
    Nov 2005
    scotland
    The rubber inserts where the caliper slides go through maybe the problem. Corrosion of the caliper body pushes against the rubber inserts. you need to remove the inserts clean out the corrosion and refit.
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Quote Originally Posted by james.stoogies View Post
    yes thats the same as iv'e done tonight, where the inserts sit was all grown up with corrosion stopping the slider pins from .......well sliding, cleaned it all up and seems alot better. would be worth checking
  1. calliper colours
    By daddyjay in forum Photoshop section
    Last Post: 29th March 2012, 21:58
  2. calliper paint ?
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2011, 22:12
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Calliper Removal
    By Bogz2000 in forum Suspension, Wheels & Brakes
    Last Post: 24th August 2009, 15:42
  5. New calliper decal's
    By shan in forum Styling
    Last Post: 13th October 2008, 21:36
