Thread: HID's fitted, now an emissions light!!
    Regular Member Vectra_Power's Avatar
    York
    Question HID's fitted, now an emissions light!!
    Hi guys,
    Fitted a HID kit to my 2005 facelift Vectra this evening. The HID's work really well, but when I re-started the car the emissions light was on.
    This is the first time I have seen this.
    To fit the lights, I removed the airbox and unplugged the MAF, but ensured it was all connected up before I re-started the car. I did turn on the ignition during fitting when the MAF was removed, to test the HID's. Do you think this could be related?
    Cheers, Chris
    Regular Member 98vectra's Avatar
    stoke on trent
    When you turn on the ignition the car will do a system check and it sounds like its thrown a fault code with having the MAF disconected.
    York
    Is there anything I can do to get the light switched off?
    Quote Originally Posted by Vectra_Power View Post
    Does the light just come on and stay on before you start the engine, and then go out once the engine is running?
    If goes out once engine is running, it's just indicating a stored fault code, not a current one and will self extinguish after a few days / clean start ups.
    York
    It stays on after the engine is started. Can I remove the wire from a battery terminal perhaps to re-set the light?
    Glasgow
    It will go off within 2 weeks my friend.
    York
    Quote Originally Posted by byebyeitsagsi View Post
    It did this morning
    Glasgow
    Result
  1. HID's fitted!
    By Danialj32 in forum Quick Photo Album
    Last Post: 2nd November 2009, 21:19
  2. hid's fitted
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2009, 01:33
  3. HiD's now fitted
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 19:14
  4. HID'S fitted
    By bigmac in forum Styling
    Last Post: 1st February 2009, 13:28
  5. hid's fitted
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 11:29
