Thread: Help needed please
    Jan 2010
    Yorkshire
    Default Help needed please
    Hi all, My Nearside indicators are clicking fast, i have replaced the bulbs but still no joy. Any ideas?
    Regular Member kns's Avatar
    Northampton
    Faulty Relay maybe.
    Regular Member mat osborn's Avatar
    Jan 2008
    leicester
    are all the bulbs the same wattage as the old ones
    Blantyre
    Have you checked all bulbs......
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think you ill find that either a side or front indicator bulb has blown which causes the any remaning bulb to flash fast.
    Jan 2010
    Yorkshire
    I have replaced all the bulbs with the same wattage as the original. All the connections seem ok aswell. Where abouts are the relays? And how will I know if one has gone?
    Worcs/Staffs/Westmids (ish)
    Has the car ever had LED's fitted? if so there may be a resistor still wired across the lamp.
    However, I think this will be fixed with a new relay.
    Jan 2010
    Yorkshire
    where abouts are the relays located and how will i know if it is faulty? Thanks for all the responses
    Jan 2010
    Yorkshire
    Hiy guys, still struggling with this, where abouts is the relay located? I have just done my gid upgrade and the screen is saying to check the indicator bulb at the rear, I have removed the bulb and out it back in but still no joy. Every so often the indicator will fuction normally for a few mins but then clicks fast again. Am I missing anything?
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
