Results 1 to 10 of 11
Thread: Anyone got sticky NSR calipers after the snow?
    Regular Member Readster's Avatar
    Plymouth
    Default Anyone got sticky NSR calipers after the snow?
    Just wondering if anyone else's Vec has a slightly sticky NSR caliper after all the snow and salt?
    I thought that regular pressure washing would help....silly me
    Sunny Dartmoor
    I had my O/S/R one seize on me last week,i put it down to no pad left.
    May 2006
    scotland
    Quote Originally Posted by glenboy View Post
    The pad was not there?
    Full Member spennny's Avatar
    Blantyre
    Astra G or H was famouse for this, as they have the handbrake cable inside the plastic sheath, water gets in, it freezes and brakes jam on for a bit,
    Regular Member garvey's Avatar
    Co Durham
    I got the same problem
    Plymouth
    I'm going to strip & clean the rear calipers.
    The stickyness is worse when the cars loaded. Maybe the handbrake mechanism or cable is faulty too.
    We shall see
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    iv'e got it on my osr, now it's stuck on the drive till i get it sorted.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Yeah I've had this since xmas week! I've been posting about mine but not got very far.
    Mine only really sticks after it's been standing for a while (like overnight or at work), it seems as it heats up it eventually releases off. Last night I didn't apply the handbrake but instead left it in gear, this morning it wasn't stuck at all! So hoping it's the cable to fault rather than piston (which I cleaned up when replacing the pads just after this problem started.
    Si
    Plymouth
    Pain isn't it. The handbrake guides, cable or something must be worn/damaged.
    This is getting expensive
    Plymouth
    I took both rear callipers off today, thoroughly cleaned the pads groves, callipers, handbrake mechanism, rewound the pistons, polished the slider bars and put it all back together and hey presto...no bind and no squeal.
    Good old copper ease
    One trick I have learnt is to fully rewind the pistons so that they fit properly onto the anti squeal springs on the inner pads when you press the brake pedal.
    The Vec Estate drives better too.
  1. Sticky oil?
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 21:42
  2. vxr calipers/ 314mm calipers needed
    By rozzer2006 in forum Handling & Braking
    Last Post: 17th September 2012, 11:28
  3. Replies: 2
    Last Post: 8th October 2011, 02:07
  4. front calipers? back calipers?
    By kenny1zero in forum Handling & Braking
    Last Post: 19th July 2008, 08:11
  5. Sticky Sub
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2006, 03:28
