Thread: How do I reset EMS light ?
    Regular Member Fash's Avatar
    Doncaster
    Default How do I reset EMS light ?
    Quick question-instead of waiting X amount of trouble free starts to clear the EMS light, can't I remove the connectors on the battery terminals and leave them off for an hour or so ? If so, do I need to remove both, or just the red terminal ?
    Ta
    Steve
    Jan 2010
    leicester
    20 starts works sum times not all, will destroy ur deisel glow plugs if ur a deiseler but taking the red one of is fine, 15 minutes is long enough but ppl tend to leave it half an hr. dnt forget radio code.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I believe disconnecting the battery for at least an hour does indeed reset the engine ECU and thus extinguish the EML. Disconnecting one terminal does the job perfectly well.... choice of colour is entirely up to you.
    You only have to hope the original cause of the EML doesn't recur or you'll be doing the same thing over and over until you fix the cause instead of the symptom.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It may turn the light off, it may not. It depends on the fault and EMS system.
    I would personally disconnect the neg - best practice.
    Doncaster
    Quote Originally Posted by Ste View Post
    Thanks, will do that tomorrow and see what happens
  1. reset service light
    By j2cams in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2011, 12:41
  2. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  3. How to reset spanner light?
    By busterpoo in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd March 2009, 13:56
  4. CAT Light stayed on , Now reset
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 14:26
  5. Service Light Reset
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2008, 18:19
