Results 1 to 10 of 14
Thread: lambda sensor problem
    Regular Member dan1983's Avatar
    North London
    Default lambda sensor problem
    Hi just wondering if this has happened to anyone else, bought my car few years ago and did the air box mod, as soon as i did this the emissions light came on, i just ignored it until about 2 months ago when i wanted to sell the car, i had the fault code read and it came up with lambda sensor, so i changed the first one, light still came on, then i changed the second one but when i ordered the second one from ebay with the same part number it came with a shorter lead but wire colours matched up so i cut the old coneector and used that to make it longer, but light is still on, and fault code is still lambda sensor bank 2.
    Anyone got any ideas as i really need to sell the car.
    North London
    oh by the way the car is the 2.0t edition 100
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You don't have a bank 2.
    Are you sure it's not bank one sensor 2?
    North London
    yeah sorry it is
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What fault code did you get?
    The second O2 sensor is to check if the catalyst is working.
    Aug 2006
    Is a very naughty boy
    It could be the maf putting in too much air so the lambada sensor shows a fault with the emissions being wrong, you need to read inbetween the lines when fault finding.
    North London
    Hi big sig, sorry i dont understand, when i did the air box mod i took the mass sensor plug out, to do the mod, put it all back and thats when it started, since then i have unplugged it and plugged it back in but nothing
    Aug 2006
    I am saying that it may not be the lambada sensor thats wrong, it could be doing its job as its seeing the wrong emmisions due to a fault somewhere else, maybe the maf or an air leak somewhere.
    North London
    hi what does the maf do and are they expensive , it sounds like it could be the maf as it happened straight after doing the air box mod, which allows more air in. the fault code is P0140.
    Aug 2006
    MAF= mass air flow. You said you unplugged it, is it back in correctly?
  1. Signum turbo lambda sensor problem
    By Rasher in forum Engine & Drivetrain
    Last Post: 25th May 2012, 19:59
  2. lambda sensor
    By wcr in forum Engine & Drivetrain
    Last Post: 11th November 2010, 00:20
  3. Lambda sensor
    By vectra 120 in forum Engine & Drivetrain
    Last Post: 11th September 2010, 23:31
  4. Lambda Sensor
    By Sambor in forum Engine & Drivetrain
    Last Post: 14th June 2010, 19:43
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
