Thread: possible clutch problem
    WIGAN
    Default possible clutch problem
    Hi does anyone know what may cause these symptoms
    noise from gearbox area when sitting at tickover alsoscrapping noise from clutch if you push pedal slightly down but disappears when fully depress, sat in neutral rev engine to around 1000/1200 rpm and car shakes press clutch and it stops , its a 150 bhp 1.9 tdi sri 2007 car ,still under warranty so need to find out so i can get it back and sorted.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Eek
    its your dmf mate...........do a search , there is loads on here about it....sorry not cheap.
    but don;t matta under warrenty
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Very common problem your dual mass flywheel is fubard expensive job lucky you have warranty(i dont!).
    WIGAN
    do you need to fit a new clutch with it aswell ,just to give them a real heartr attack
    Regular Member brad69bj's Avatar
    Jun 2009
    Leeds
    Yeah you need to fit a new clutch kit at the same time. Lucky for you its still under warranty. Mine was out of warranty by 3 weeks! , cost me £500 just to do it myself.
  1. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
