Results 1 to 10 of 13
Thread: Falkland performance Dyno Run!!
    Regular Member sberrow's Avatar
    Newport (Gwent)
    Default Falkland performance Dyno Run!!
    I have had a few problems this week with loosing boost presure and power. I took it to Falkland performance in Glenrothes today to try to show them the problem. Decided to do a power run to astablish the problems. As they brought it in the operator give it a quick rev, turbo clearly working...
    They set the car up.
    1st run clearly down on power. (ill take some pics of the run and post shorlty). As a result 2 faults found, Turbocharger bypass valve malfunction, Catalyst system effiency (bank 1) too low.
    The second is due to the car running a decat.
    He checked boot pressure. 0.5 bar. below standard
    I expalined that the fault can some times be cleared by turning off and starting again. so he did, car started a quick rev showing now working.
    2nd Run clearly up on 1st however turbo pressure comes in spiking all over the shop to a peak of 2.1bar!! and cutting out at 4100rpm.
    Anyway car is going back there on wednesday as we ran out of time today to try find the fault and sort the problems. I will update as i progress this problem. Dyno runs will follow when i get the pics together.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Sounds like it could possibly be costly, hope you source it!
    Newport (Gwent)
    Default pics
    This is a clear as i could get. results to follow
    Newport (Gwent)
    1st run 147.8bhp 153.8lbf.tf torque
    2nd run 235.8bhp 284.0lbf.ft torque
    Sep 2009
    Warrington
    Quote Originally Posted by sberrow View Post
    Lol something's definately not right there then.
    Jan 2006
    Dalriada
    We all had a meet there a while ago, my 2.0T which had a superchip's map on it at the time was 180Bhp but the map did not take to my car so it was removed. Signumboy's signum ran 215-220 i think and that was with BSR stage 1 - so your second run must be pretty close to what your expecting power wise??
    Finger's crossed you get your issue's sorted though as it seem's like you have a quick car in the making
    Newport (Gwent)
    already produced 278bhp on this setup! i was after 255bhp ish with the lower boost
    Newport (Gwent)
    Problem found!!!!!!
    Once again the boost solinoid... Currently looking at other options to replacing it like for like.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    One thing to note mate is that Falkland performance's figures are sometimes lower than other places
    Newport (Gwent)
    i noticed that today, a guy not happy with 278bhp astra vxr with a 300+ conversion.
  1. Day on the Dyno
    By rickisgrate in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2012, 12:01
  2. Don't Dyno like this!!!
    By cj_quest in forum The 'Off Topic' room
    Last Post: 7th December 2010, 16:52
  3. DYNO MAT or the like?
    By Dose in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2010, 22:47
  4. Dyno run....
    By david.aka.judas in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 7th March 2010, 17:21
  5. Performance box Measure your cars performance..
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2007, 18:09
