Results 1 to 10 of 14
Thread: Subwoofer Wiring - Different Gauge Help!
    May 2008
    Doncaster
    Default Subwoofer Wiring - Different Gauge Help!
    Hi,
    I've got one of these for my car:
    http://www.gumtree.com/london/75/52231875.html
    It's rated at 550w RMS and 1600w peak so I was wondering, do I need an 8 gauge or 4 gauge wiring kit.
    I like this:
    http://www.caraudiocentre.co.uk/prod...60_p-22585.htm
    But this is 4 gauge but says it only works with 1200w - will this be suitable for my subwoofer or should I get something else?
    Thanks!
    Regular Member SRimonkey's Avatar
    wednesfield
    depends how powerful ya amp is but i`d just use the heavier
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    I'd agree with SRimonkey. The 4 gauge should, in theory, be a better bet. Thick wire lowers resistance and therefore less energy is wasted in the wires themselves.
    I can't imagine it making too much of a difference what one you go for but someone correct me if I' wrong! HTH
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Get the biggest cable you can afford! For 550w RMS I wouldn't look at 8 gauge, 4 gauge and above.
    May 2008
    Doncaster
    Cheers for the help guys! I like my music to sound good but that's as far as I get with tech specs on speakers etc!
    I'll start looking at 4 gauge or better, what makes are any good? I assume they're all the same but any preferences?
    Am hoping to get down to caraudiocentre in notts for it fitting on Friday if all goes well!
    May 2008
    Doncaster
    Am looking here to get the kit (as they sell the aerial lead I need too):
    http://caraudiosecurity.com/shop/pro...ring-kits.html
    There's 3 kits around £40 for 4 gauge and I don't know which one's the best (or more suitable) the vibe, autoleads or CAS custom.
    Any help is appreciated!
    Cheers guys.
    Maidstone, Kent
    Personnally I'd go with the Vibe kit:
    http://caraudiosecurity.com/shop/pro..._id/11827.html
    If you want me to confuse you more there are other manufacturers out there, Stinger, Tsunami or Streetwires to name but a few, but unless you want to have a more complicated system then the Vibe kit will do you fine.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    Quote Originally Posted by alzsxi View Post
    May 2008
    Doncaster
    Got the wiring kit ordered, car booked in on Friday so hopefully will be a big improvement to sound quality!
    Will see if I can post some pictures when done!
    Regular Member Matty777's Avatar
    Jan 2010
    Nr Maidstone
    4awg will be better a SAFER than 8awg. Anything above 4 starts to become very unwieldy and hard to install and probably overkill for a one amplifier system.
    I ran a 2 amp system (a 2 x 240RMS sub I think and a 200RMS front speaker set up) and 4awg was fine.
    Also if 4awg is overkill for your system, it then adds scope for upgrade, that 8awg won't.
  1. Wiring a subwoofer
    By colleyt in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2012, 14:56
  2. boost gauge wiring up
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2011, 13:13
  3. Connecting / Wiring up a Subwoofer
    By nickabbott2008 in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2008, 15:19
