Thread: Signum 1.9CDTI Low power under 2000 RPM
    Jun 2009
    Default Signum 1.9CDTI Low power under 2000 RPM
    Recently started getting low power on my signum 1.9 CDTI (150) below 2000 RPM then when the turbo kicks it it's off like a rocket.
    Read on a few forums that it's most likley the EGR valve so over the weekend I took it off and gave it a good clean up but is still no better.
    I would go and get the Diagnostics done but like a fool I took the battery off and reset the ECU yesterday and now the EML doesn't come on anymore so I assume I have cleared the fault codes out of the ECU.
    Any advice on what else this could be? do you think I should buy a new EGR valve and see if that fixes the issue?
    Any advice is much appreciated.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Did you fully strip down the EGR to clean, i.e. the solenoid side too..?
    Alot of times is the solenoid side that sticks which causes the low down power problem, just cleaning the inlet side could not be enough.
    Failing this of course, have you checked your swirl rod is still attached..??
    http://www.vectra-c.com/forum/showpo...31&postcount=6
    (3rd and 4th pics show the rod).
    Jun 2009
    No I only cleaned the metal side.
    I have just found the "how 2" which shows how to clean the solanoid which i'll try this afternoon and also check the swirl thingy when I do this.
    Lancashire
    Trim : XP NAV
    Did the spring move freely do you remember..?
    Jun 2009
    Do you mean the spring inside the metal side (the actual valve) then yes it did.
    The little pin that pushes out of the solenoid was pretty much flush with the metal flange, is this correct when the valve is not in use? I'm just hoping that it's the solenoid and not the swirl rail as I hear you need a new manifold to replace the swirl rail.
    Jun 2009
    Just had another look under the bonnet now I know what a swirl rail looks like and guess whats it's not attached!
    Lancashire
    Trim : XP NAV
    Sorry to hear it mate, thats about £600-£800 to get it replaced (at an Indy, not VX).
    Jun 2009
    Gonna try and repair it tonight
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    How did you get on!?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Try to repair the swirl bar it usually works and lasts for some time, i also read from your post that you said that the little pin the comes out from the solenoid was nearly flush! NOT correct!! it should be out and very free, will post pic, don't forget the hole in the manifold will want cleaning also, and give the boost sensor a good clean!.
  1. Slow power when under 2000,
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 17:15
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 5th June 2011, 11:30
  3. No power under 2000 rpm
    By Munch85 in forum Engine & Drivetrain
    Last Post: 2nd June 2011, 09:50
  4. Exhaust emission light and loss of power below 2000 revs
    By craigb in forum Engine & Drivetrain
    Last Post: 14th March 2011, 15:08
  5. Lack of power und 2000 rpm ??
    By nigec in forum Engine & Drivetrain
    Last Post: 21st March 2010, 19:50
