Results 1 to 10 of 11
Thread: ARB bushes
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default ARB bushes
    Well after managing to get drop links changed, figured I'd do the bushes aswell, bought off euro car parts after puttin my reg in. Finally got the bush out after blood sweat and tears found out they sent the wrong size but I got it off and I couldn't see any signs of wear :/ any ideas?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    i would just change them mate i done the same thing i checked them and they never had any play in them what i could see, but i kept having a crunch noise at the front and it was ****in me off so i just brought the bushes and changed them and it sorted it out, so i would just change them easy job tbh
    Sep 2009
    Warrington
    Yeah emailed euro car parts asking for a refund, and the proper bushes. Was just a bit baffle as to what exactly is making the noise, the rubber bushes were fine, bit dirty but still no signs of wear, and was sat snug in the clip, what is it that makes the crunchin noise?
    Oct 2009
    Sandwell
    Quote Originally Posted by Danialj32 View Post
    mine were fine i would just replace them, i was told the parts that could make the crunch is, droplinks, bushes, rad mounts, and the spring it might be hitting the cup that the spring sits in, does your car make the crunch?
    Mileage : 000
    Yep the rad mounts were a bit of an issue too.
    Sep 2009
    Warrington
    Changed the drop links, no difference, bushes seemed fine but shall replace, where are the rad mounts, easy job? They need fixing/replacing or just a spray of WD40?
    Oct 2009
    Sandwell
    open bonet and look by the radiator youll see some rubber things spray them(i think its them thats what i sprayed and there should be some at the bottom ) yea wd40 will do
    Sep 2009
    Warrington
    Quote Originally Posted by chris1804 View Post
    Ok cheers mate, will give it a go soon!
    Regular Member F33F33's Avatar
    Nov 2009
    Preston
    Vehicle : Insignia
    Trim : SRi VX-Line RED
    Engine : 2.0CDTi
    Year : 2012
    Let me know how it goes as i also get the crunch when going over bumps!
    Sep 2009
    Stratford-upon-Avon
    Me too, its been annoying the hell out of me, seems much worst when its cold, let me know how you get on!
  1. A.R.B Bushes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2011, 21:39
  2. arb bushes
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 09:51
  3. ARB bushes
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 00:29
  4. arb bushes
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 14:54
  5. Replies: 5
    Last Post: 21st March 2010, 12:34
vectra arb bushes
