Thread: Computer issues
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Computer issues
    My daughter had some friends around last night, and now my desktop doesn't work... Grrrrrr.
    Apparently they didn't do anything, but it did get knocked and switched itself off.
    Well, now I am having issues with it.
    I want to do a system restore, but I can't get it to start.
    It will not start in Safe Mode AT ALL. The screen fills up with files that it is loading etc, then it stalls at btkrnl.exe and won't progress.
    I cannot start it normally on my account (corrupt user file)
    When I start it as Admin account it starts, but there is no taskbar at all and turns off after a while with a message that some program has terminated unexpectedly and the station will close down. It then counts down and shuts down.
    There is approx 5 GB of space on the disk.
    How do I know if the restore function is working, has backed up any points? And how do I get the last point to revert back to? System restore within control panel is switched on, but I can't remember ever setting a point. Does it do it automatically?
    I was using the desktop normally yesterday before they came round.
    Mar 2007
    North East
    You can run system restore from the command prompt, info here.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Check everything is plugged in and seated correctly including memory
    Irmscher Insignia CDTI 130
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by rockh View Post
    As I said above, the computer WON'T start in safe mode at all.
    Everything is plugged in OK, it does start but then closes down af the 'NT Authority/system' commands a shut down....
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds to me something isnt seated correctly and is causing it to crash or it could be faulty memory as i had this and my computer would crash and try and restart
    Northampton, UK
    If the HDD was on and spinning when it has knocked, could have damaged that?
    Full Member Big Sig's Avatar
    Press f8 as it starts, just after the first display screen, may give you a few options.
    Mar 2007
    North East
    Sorry, should have notice you mentioned it hangs.
    Try a repair install, stick xp cd in and start the install process, don't select repair console, select new install, when you are asked to select the installation to repair press R.
    Sometimes you don't get the option to repair though.
    You could try the repair console, type bootcfg to rebuild the boot.ini and see if that helps.
    Worcs/Staffs/Westmids (ish)
    I've seen similar problems caused by a faulty powersupply.
  1. Few issues
    By fattony in forum Insignia car chat
    Last Post: 21st July 2012, 21:35
  2. EGR Issues
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 30th June 2012, 11:51
  3. Issues!
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 01:13
  4. Possible MPG Issues
    By Homer in forum Engine & Drivetrain
    Last Post: 5th November 2010, 10:49
  5. anyone added trip computer/board computer?
    By Craig1985 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2008, 02:33
