Thread: Engine temp vvt
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Default Engine temp vvt
    Cant decide if a have a problem or not. Car was running cool so replaced the stat with a genuine one, now warms up as it should but gauge sits on 90 to 92 with the hidden menu saying temp is running from 90 to about 102. Does this sound about normal, cooling fan comes of and on ok and cars doesnt boil over etc. Car spends alot of time going backwards and forwards to italy so if theres a problem its alot easier to get it sorted here! I did notice on the autovaux website the stat is listed as 105 centigrade. Might be nothing?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Sounds about right to me mate as coolant boils at around 110ish C
    Regular Member petel's Avatar
    Nov 2007
    bristol
    my 1.8 vvt sits bang on 90,goes up tp 92 when sat in traffic.Its like this however cold or hot it gets outside
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the vvt has two temp sensors and has a controled thermo stat the engine temp can be a lot higher / lower than the rad temp so the "secret" menu maybe reading the temp sensor in the rad /engine where the guage might be a ecu controled display between the two figures ...
    Regular Member eaglepva's Avatar
    Up North
    Secret Menu?
    Nov 2007
    Northants
    Sounds like its fine then cheers, am so used to the gauge reading nothing its always a shock to see it on 90 now, thanks to all. Search secret menu, loads on the site about it.
  1. what should teh engine temp be in 1.9 150
    By kirky2k4 in forum Engine & Drivetrain
    Last Post: 26th January 2011, 22:16
  2. Engine Temp.....
    By skip85 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 01:51
  3. Engine Temp
    By bigmac in forum Engine & Drivetrain
    Last Post: 17th May 2010, 20:36
  4. engine temp
    By iasha in forum Engine & Drivetrain
    Last Post: 27th January 2010, 00:39
  5. engine temp.
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 21st October 2009, 19:56
