Thread: New Engine
    Oct 2009
    Teesside
    Cool New Engine
    Guys,
    My car is an 2004 1.9cdti 150 and I have the following things wrong:
    Inlet Manifold Rod on its way to coming off
    DMF rattling like its trying to get out
    Its also 10k from a new timing belt etc needed.....sooooo i'm wondering if it would be cheaper to replace the engine for a newer one i.e a 2007 engine.
    Is this possible or are they different ecu's etc?
    Or should I just get the work done on this one when it needs it?
    Rob
    I'd imagine a new engine will be about the same cost as your car is worth mate - if you know the rest of the car is sound then you're much better off repairing yours...
    May 2007
    West Yorkshire
    2007 may still have the inherent engine issues, repair yours then you know the history. It would be a real ball ache swapping units only to find in a few miles that one needed the same.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    engine change is last option when big ends go or rings,i would repair yours at least you know its all done and dusted then
    Irmscher Insignia CDTI 130
    Oct 2009
    Teesside
    I'll fix my badboy then
    thanks guys
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
