Thread: engine temp help needed
    west yorkshire
    Default engine temp help needed
    never seems to go past the 1st mark on the gauge, then when parked up idling the temp goes back down to 0, soon as i move it goes up again, only asking as my old vec b temp used to move even if sat in traffic,
    1.9cdti 120
    norfolk
    Vehicle : vectra
    Trim : design
    Engine : 1.9 cdti 150
    Mileage : 132000
    looks like you may need a new thermostat. I had the same problem on my 1.9 150. New thermostat and housing from vx was 43.00 +vat. Fitting was quite straight forward. After removing battery and tray access to the two bolts is good.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Common 'normal' temp seems to be roughly 1/3 up the gauge - somewhere around the 85 mark I think. Despite diesels always running cold anyway, it sounds like you might well have a stuck open thermostat.
    I'm sure one of your fellow diesel drivers will be along shortly with a slightly better idea though.
    Oct 2009
    Teesside
    Yep should be on the 86 mark....after taking an age to warm up!!!
    You defo neeed a new thermostat mate, around £56 from the stealers
    PRESTON
    Without doubt,,,thermostat. Mine wasnt moving at all off zero and the heater took forever to get warm. New stat fitted, reads right around 85 and heater toasty again. Mine is a cdti 120, pig of a job,bout two hours, damn egr cooler is in the way along with other pipes, but with abit of fiddling and patience stat comes out.
    west yorkshire
    do alot of local driving so dont warm up much, did a 100 mile motorway trip today and it never went over 80, as soon as i stoped and waited for the plane it droped down to 0 again,
  1. Engine Temp
    By bigmac in forum Engine & Drivetrain
    Last Post: 17th May 2010, 20:36
  2. engine temp
    By iasha in forum Engine & Drivetrain
    Last Post: 27th January 2010, 00:39
  3. engine temp.
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 21st October 2009, 19:56
  4. Engine Temp?!?
    By caspy in forum Diesel Engine related
    Last Post: 2nd December 2008, 09:22
  5. Engine Temp
    By Rob h in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2008, 16:25
