Thanks Thanks:  5
Likes Likes:  6
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 66
Thread: Z20NET Spec Sheet
  1. #21
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Quote Originally Posted by matrix1979 View Post
    Does any body else have this issue with the vacuum pump (circled in red) tapping noises coming from it while the engines running can be heard clearly when u hold a screw driver to it and place ur ear to the end of the driver , Also if the vacuum pump is faulty would this have anything to do with me having my lumpy idleing issue i have ? So if people could please check there z20net vacuum pump to see if theres does the above or not ill appreciate it thanks mark .
    I will check mine to tonight once its warmed up and let you know..
  2. #22
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
  3. #23
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Oops missed that chnace to do that and am out and about now without it. If one of tye other guys can't check theirs tonight I will do mine tomorrow.
  4. #24
    Regular Member Delgado900's Avatar
    Sep 2011
    Maidenhead
    What's the idleing RPM ?
  5. #25
    Aug 2007
    NORFOLK
    I'd say 800 to 850 but the needle is moving up and down slightly when the engine is idleing lumpy . What s the purpose of a vacuum pump exactly ? And would it have any affect on idling lumpy at all
  6. #26
    Aug 2007
    NORFOLK
    bump
  7. #27
    May 2006
    Mansfield
    Vacuum Pump is for your brake servo, in the dark and distant past with petrol carbureter engines you just used to tap off the vacuum from the inlet manifold, can't easily do that with modern engines so they use the same technique the diesel fraternity have always had in the shape of a dedicated vauum pump.
    SJ
  8. #28
    May 2006
    Mansfield
    Sorry only gave you half an answer, I believe the vacuum pump also operates various solenoids, so I suppose it is possible that a faulty pump may cause some other symptoms, how do your brakes feel when you apply them hard ?
    SJ
  9. #29
    Regular Member J's Turbo's Avatar
    Sep 2011
    luton
    Hi mate, you reckon you could source me a wiring diagram for the ecu for that engine z20net?
  10. #30
    Aug 2007
    NORFOLK
    Quote Originally Posted by sjanisz View Post
    SJ
    Not to bad but I suppose they do feel a bit weak on braking when applying it hard cheers for your info think I might just pop a new one on and see , looks easy to fit ?
  1. exclusive spec vs club spec
    By rjw in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2012, 20:10
  2. what does this mean on my service sheet?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 09:52
  3. Z22YH - 2.2 16v Ecotec Direct Spec Sheet
    By tomtaylor15 in forum Petrol Engine related
    Last Post: 27th June 2010, 16:29
  4. sevice sheet
    By dominic32 in forum General Chat
    Last Post: 18th July 2009, 18:02
  5. Holey sheet lol
    By Dose in forum Comedy & Humour
    Last Post: 2nd May 2009, 17:22
z20net engine
z20net
z20net vacuum diagram
Z20NET E
engine 2 0 tdci opel insignia sheme
z20net cat
vectra z20net
z20net spark plug gap
motor z20net
z20net time injectionvectra 2008 engine diagramvectra 2.0 turbo specz20net engine diagramz20net engine specsvectra 2.0 engine on blocksvauxhall insignia 2.0 turbo diesel engine diagramvectra c z20net specz20net gt 20 max doladowaniez20net garrett turbocharger connection diagramopel vectra c 2003 atmosphere thermometerwhere is the boost sensor located on a signum z20net enginez20net bypassventil Z20NET where is the coolant drain plug on vauxhall zafira 2007z20net signum boost sensor
