Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Replacement for the auto gearbox cooler
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Default Replacement for the auto gearbox cooler
    Has anyone fitted an aftermarket cooler for the automatic gearbox cooler? I'll be doing some work on my gearbox, mainly changing the valve body and oil, so I was thinking maybe I can find an aftermarket cooler for it. I definitely think it would be much better than the original one, which is shared with the main cooling radiator.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Well, as I was saying earlier, I was looking to change the automatic gearbox oil cooler with an external one. This week the job was done. The cooler I bought from eBay.de was made for Audi A6 Allroad Quatro, 5 gears automatic, so I think it will get the job done.
    Cooler mounted:
    Final look:
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Well done mate, a thing vauxhall should have done long ago!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Very tidy and professional looking mate, well done
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Yes Dose, that's what I was thinking when I heard all the trouble some people have gone through because of GM's bad design.
    Thanks John! I tried to make it as profi as I could. It sits right as I wanted it to sit, very close to the A/C cooler. It gets a little warm and there are 2-3 degrees Celsius outside. I wonder if it will do a good job when it gets really hot outside. Anyway, I really think it's better than the original solution.
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Great job Lao! What was the reason for changing the VB?
    Bent, my name is Bent
    Mods: I polished it in september...
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    A really bad jerk when going from 5th to 4th on kick-down. Otherwise, it was all good. I think I'm gonna put it on eBay, for someone who has other problems than mine.
    The other reason was that I really love my Vectra and I decided to keep it for 2-3 years.
    Sydney, Australia
    Hey folks,
    I've read through the whole thread and have been inspired to flush my trans and install a cooler! Can someone please take a picture or describe which of the two transmission cooler lines is the one you use to pump the fluid out?
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    I don't think it matters, as long as you use one IN and one OUT.
    Regular Member csd_19's Avatar
    Oct 2006
    Aberdeen
    Engine : 2.8T
    Nicely done Lao, looks spot on and definitely takes care of that worry.
    My dad's Vectra had to get the box replaced (under warranty) after the cooler seals failed. They pulled the valve body cover, saw the white mess and said straight away "that's a new transmission needed". Even though they replaced the trans and the radiator seals etc with uprated parts, I've always been a bit worried it'd fail again.
    Methinks a separate cooler is just what's needed! (Also going to do one on the Volvo V70 too, that's got the Aisin 6-speed auto in it and has the same stupid setup....)
  1. Oil cooler replacement & Coolant Flush query
    By kon123 in forum Engine & Drivetrain
    Last Post: 29th September 2009, 19:47
  2. Automatic gearbox oil and cooler info required.
    By m0cea in forum Engine & Drivetrain
    Last Post: 21st September 2008, 00:05
  3. Auto Gearbox oil cooler seals
    By Jamesdti in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:25
  4. Auto v Manual gearbox replacement cost
    By cabbage in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2007, 23:30
vauxhall vectra c auto trans cooler replacement
vectra 2.8t oil change www.vectra-c.com
where is the valve body located on opel vectra c automatic gearbox
changing a radiator vectra c automatic
opel vectra transmission cooler
vectra c radiator to fit an auto gearbox
vectra c auto gearbox cooler
