Thread: Factory Xenon Bulbs
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Default Factory Xenon Bulbs
    As above has anyone changed the standard HID bulbs on the vectra. Ordered 2 6000k D2S from hids direct and when I went to change them the standard ones are D1S . So did a search about it and found out that you should be able to remove the D1S bulbs from the metal bit at the bottom of the bulbs and then fit the D2S in its place. Took the headlights off the car and removed the standard bulbs but cant figure out how to remove them from the metal base. Has anyone done this before
    Standard D1S bulb
    Replacement D2S bulb
    Actually looks like a house bulb type fitting ie push in and turn to locate pins into holder.
    Any help appreciated
    Regular Member neilybhoy1888's Avatar
    caithness
    take it you have tried just twisting and pulling??
    other than that am clueless
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yeah just looks like a push twist job
    Wouldn't want to force it though just incase
    ayrshire scotland
    My thoughts exactly John
  1. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  2. factory xenon not a vectra
    By DAVIDD88 in forum The 'Off Topic' room
    Last Post: 5th January 2012, 19:56
  3. Factory Xenon Conversion
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 3rd January 2012, 14:59
  4. Factory Fitted Xenon headlamps
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2010, 13:19
  5. Xenon bulbs - factory fit 2002 GSi (non AFL)
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2008, 22:38
