Results 1 to 10 of 15
Thread: No instrument lights or interior lights.
    Sheffield
    Default No instrument lights or interior lights.
    Hi guys, I recently removed the bulb from my glove box light fitting to see if it was a cause for draining the battery (it wasn't) and when I replaced it it blew something out in the dash as soon as I made the two contacts and now I have no interior lights whatsoever, the heated seat controls don't work and the intstrument dials don't light up. A real problem when driving at night!! The cd player and heater controls all work and light up, and on the instrument panel the mileage display and gear select screen light up but the dials don't.
    I have checked all the fuses to no avail and the dealer wants £77 just to have a look to see what the problem is, on top of the £1545 I gave them last week!! So I thought I'd see if anyone could help before shelling out.
    Thanks in advance, Christian.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Nearly always the fuses...
    Have you tried all THREE fuse boards.
    Under Hood Electrical Centre (engine bay fuse box - FU 7 and FU 13, FU 31 and FU 33.
    End of dash - CIM power feed = FI 10
    BCM feed = FI 7, FI 9 and especially FI12
    Rear fuse box - not clear from documentation.
    I can solve this one
    Fuse F4 in the passenger fuse box on the end of the dash. My dial lights still worked but that may be a difference in the facelift wiring as they're alays on regardless. Same thing happened to me when I shorted the bulb to the dash crossmember and spent weeks checking everything...
    http://www.vectra-c.com/forum/showthread.php?t=94557
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Will make a note of that!!
    FI 4 in the manual for my 05 Vectra just has a "-" next to it - (no function),
    but TIS states that this is used for "Accessories".
    Yup, my Haynes said nothing either - giveaway was when I found the blown fuse in F12 which didn't have a function either. I repaced it but didn't solve anything, then tried fitting it in the F4 position and voila!
    When I originally checked them I must've checked it, thought it was ok, and put it back in the wrong place. Just how many mistakes can one man make in 5 seconds...
    Sheffield
    Thanks guys, turned out to be the battery overload protector fuse, one of few I didn't check! Methinks a clearer description of each fuses responsibilities could be provided in the manual!
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Would that be FI 12, me thinks....?
    Sheffield
    It was indeed, as identified by your good self. Thanks again.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You're Very Welcome!!
    Just going to lie down in a dark corner and wait for my big head to shrink back to normal size. gloat!! gloat!!
    Quote Originally Posted by Robsey View Post
    Just ignore my contribution why don't you...
  1. DIY Map lights, Interior lights Off button console?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 10:35
  2. Lights failed on instrument panel
    By Chuda in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2012, 01:20
  3. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  4. Instrument Panel dials lit when external lights off
    By Street N in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2009, 23:26
  5. Instrument Lights
    By jimmy55 in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2008, 13:02
