Results 1 to 10 of 28
Thread: Help car wont start. 2.2 dti
    Regular Member Middo's Avatar
    Swindon
    Default Help car wont start. 2.2 dti
    The car has been stood for nearly three weeks, went to start it today and the battery was flat (just clicked when I went to start it)
    I have tried to jump start it but it fires then dies, it seems to have power now as it just turns over after that.
    Help I need the car for monday
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Has it been sat on an incline by any chance?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Does it die with the doner car still connected or is it when the leads are removed, if so the battery is so low it might need a good charge before it will allow the car to run.
    Swindon
    it has been parked on a level ground. It dies whilst still connected to the jump car, maybe it needs more oomf and it just needs more charging. Maybe I have even flooded it?
    It has a 3/4 full tank btw.
    All
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you have a charger give it a boost if the battery from the doner car is the same or very similar swap them over to try the car before you spend any money on a new battery
    Swindon
    the other car is a clio, i will try and get a boost from my mates van tomorrow, pity the VX parts desl is shut as I have a card. Saying that I have a Halfords one.
    Jan 2010
    glasgow
    sounds like the battery
    Swindon
    hope so, just been out and gave it a try it fired then died. It didn't want to start after that.
    What size battery are they 096? pity vx parts are shut
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Leave the jump leads connected and run the donor car for a few minutes. Earth lead connected to engine block. Then crank and crank and crank - I would dare bet it starts eventually.
    Look to see if any white smelly smoke come out the back whilst you crank
    When it eventually goes, leave the leads connected for another minute with both cars idling.
    Then disconnect the leads and go for a spin in the Vec
    Swindon
    Battery off now and its on charge. Some smelly smoke did come out like you said.
  1. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
