Thread: inlet manifold
    Sep 2009
    suffolk
    Default inlet manifold
    does anyone know if its ok to keep driving when the linkage bit is broken off completly , somtimes it drives ok then others i loose all power , but i cant get it fixed till wednesday so will it be ok to keep using it as it is ?? sorry pics not to good , but its very dirty where number 4 has pushed up out of the manifold , which has knocked the whole lingake off
    Kingston Upon Hull
    If you do a search you will find a lot of people have this problem Me too
    I dont know how long mine was off but when i phoned V/hall main dealers they said nothing to worry about it will be ok without it
    I have since repaired mine with the top washer method
    Sep 2009
    suffolk
    yeah had a read about and couldn't really see anything saying if it harms the engine or not to have it dis-connected
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    It shouldnt harm ther engine immediately however long term disconnection I wouldnt advise as it is there for a reason.
    I would get it fixed as soon as finances allow. I drove with mines off for a year. If it has fallen off of its own accord then thagt means the bearings have given up and may collaps causing the flaps to be sucked into the engine.
    The engine may seize or it may crush them up and spit them out the exhaust but personally I wouldnt take the risk on looking back.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Regular Member si_sri's Avatar
    Nov 2009
    TELFORD
    hi Asty,
    mines off too, I did attemp the rubber washer repair but that failed after a weeks,(think I have the wrong glue rubber keeps dropping off ! - anybody know whats best to glue with ?) but to be honest i could tell no difference when it was on or off?!....but then again your flap guides / bearing areas do look really oily compared to mine which is probably more of the problem with the air leaking on the induction side, rather than the flap operation hence the performance issue sometimes.
    Did around trip of 80 miles on motorway and "A" road today and got 52mpg...thats not bad considering mines done 76 thou with no swirl flap operation..and i wan't tootling along either !
    i would consider replacing my manifold only when it really starts to play up etc.......
    Good luck with the repairs though.....
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by si_sri View Post
    hi Asty,
    I had a bust intercooler which masked my manifold issue, but I has to get the manifold replaced as when the intercooler was replaced it would cause the flaps bearing to give way eventually.
    Wales, UK
    Not too sure on the manifold but ive always used araldite glue. Its come in 2 parts, you mix them both and god does it stick ! Try it...
    Sep 2009
    suffolk
    its going in on wednesday to be looked at then fixed under warrenty , its just weather or not i should keep driving till then , i have about 200 miles to do between now and then ?
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    Quote Originally Posted by asty View Post
    i will be ok to drive, just dont cane it, if youre getting it done under warrenty everyones happy
    the performance will suffer though, either at low or high revs due to the swirl valves either being stuck open or closed
    Sep 2009
    suffolk
    Quote Originally Posted by Grimo72 View Post
    yeah thats what i thought , but just wanted to hear it from others .
    Just been out in it and it ran great , so strange how it dosnt cause a problem all the time , it does smell a little tho
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
