Thread: Cooling fans run constant - Vectra c 3.2 V6
    Apr 2009
    Huddersfield
    Default Cooling fans run constant - Vectra c 3.2 V6
    Help please, the cooling fans run constant on my veccy, I changed the coolant temp sensor but it still happens.
    Any ideas anyone ?
    Full Member Big Sig's Avatar
    coolant fans or a/c fans?
    Common electrical problem, probably a failed radiator switch
    This usually leaves the radiator fan running at all times, often leading to flat batteries
    Apr 2009
    Huddersfield
    thaks for the response - where are these switches ?
    Oh and the problem persists with or without the air con on
  1. cooling fan running constant
    By Griff72 in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2012, 17:20
  2. Cooling Fans
    By Griff72 in forum Engine & Drivetrain
    Last Post: 15th August 2012, 17:57
  3. Changing dual cooling fans
    By Jonsey in forum Engine & Drivetrain
    Last Post: 4th July 2011, 21:59
  4. Engine Cooling fans working correctly?
    By luke4487 in forum Engine & Drivetrain
    Last Post: 28th April 2011, 11:15
  5. Cooling fans
    By Darrell Lossau in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2009, 22:18
vecctrs c 3.2 v6 coolant temperature sensor
vauxhall vectra v6 constant fan
