Thread: manifold help
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default manifold help
    going to do the swirl valve repair today and tried to get the bar out but i cant seem to get it out as the fuel rail is in the way!
    did everyone else take the fuel rail off to get at the bar or did you get it out another way?
    is it ok to take the fuel rail off?
    cheers
    Kingston Upon Hull
    Hi if you are talking about the cdti 150 /1.9cc engine i did NOT remove any thing the bar will come out its a bit tight
    I think its more to the right of the manifold that i got mine out
    You dont need to bend the bar
    Have you got the right tap washers [ The thin ones ] 9/16 x5/32 x3/32 code wb521Qv2 that's B&Q
    Aug 2009
    wirral
    cheers just got it out and yeh i have some washers to glue onto it!
    thing is i knw the third swirl valve wont be moving freely as this is the actuated one but only 2 of the other three move freely! one is quite solid! is this a problem?
    Kingston Upon Hull
    Quote Originally Posted by Graeme01 View Post
    Yes i think it may be all of mine were free to move except the 3rd one thats probably why yours bar has come off
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    it sounds like you may be heading for a new manifold £$£$£$£$
    Aug 2009
    wirral
    managed to fix the seized swirl valve with a mixture of a few cans of wd40 and some light taps with the engine on to soak in the wd40.
    i have also fixed the actuator bar but not fitted yet but even just freeing up the swirl valve has made the world of difference.
    how is the actuated swirl valve supposed to move i.e. is it supposed to spin round or just vibrate from side to side?
    Kingston Upon Hull
    When the bar is on and you rev the engine the bar moves to the left looking down on it or at least mine dose
    Jacko
  1. is it the manifold?
    Last Post: 15th June 2010, 16:09
  2. manifold help
    By Graeme01 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:20
  3. 2.4 manifold
    By lizard in forum Petrol Engine related
    Last Post: 15th November 2008, 22:00
  4. manifold
    By rob_gsi in forum Engine & Drivetrain
    Last Post: 25th March 2008, 22:21
  5. manifold will it??
    By beefycol in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2007, 21:28
