Thread: what do i need?
    Cambridgeshire
    Default what do i need?
    wanting to change the oil on my pre-face 1.8, im guessing i need:
    The oil
    A filter
    Engine flush
    possibly a sump plug or o-rings/washers??
    part numbers would be great if anyone can, thankyou.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Save yourself the time, effort and probably some of the cost... check National Tyres and KwikFit. My 3.2 GSi done at National is just over £35 (10% discounted ordering online). I don't have to go round buying anything... don't have to dispose of the old stuff... and if anything goes wrong it's their problem, not mine.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    TBH whilst that is a good price (assuming they use the correct longlife oil) I would still prefer to do it myself, as then I know it has been done properly and whilst it would also be a few quid cheaper to DIY (VX trade club prices) price wouldn't be what drives me to do it.
    I wouldn't use flush either, don't see the actual benefit in it. You will need a T45 bit for the sump plug too and it can be quite tight and may require a bit of butchery - so a new one might be advisable.
    Regular Member Jezzy's Avatar
    S.E
    If you know how to change the oil yourself, do so - don't trust Kwik Fit. Also, as above, if your engine is running fine, then there's no benefit to using a flush, you just risk disloging debris into critical places. You should only use the flush either as a last resort to fix a problem, or if it's been used every time the car has ever had an oil change, therefore there will be less debris in there to dislodge.
