Results 1 to 3 of 3
Thread: Clutch going?!
    Nov 2009
    Bradford
    Default Clutch going?!
    Hi, when I sit with the car idleingand take my foot off of the clutch the shine seems to get a bit noiseier, is it nothing to worry about or is the clutch on it's way out?
    Bristol
    Vehicle : CDTI 150
    Could be a noisey DMF.
    Search for DMF on the forum you should get a clearer picture of the symptoms.
    Regular Member Jezzy's Avatar
    S.E
    "Clutch on it's way out" would be characterised by slip....try to move off from a start in a high enough gear that you'd expect the engine to stall - if it doesn't stall and tries to move the car, that's the clutch slipping. If it isn't slipping, then as above, more likely to be the DMF.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
