Thread: How do I illuminate my heated seat switches? Please help!!
    Dunstable
    Default How do I illuminate my heated seat switches? Please help!!
    I've bought some heated seat switches for my '06 SRi, fitted them but they don't light up as i expected. Can anyone tell me how to wire them up just so they illuminate with the others? I'm guessing the grey / yellow wire needs to be connected to the tc switch or something which already lights up but is there an easier way? All I want to do is make them illuminate when the lights are on. I know the fuses for the heated seats are in the glove box in the boot, so is a case of just fitting the fuses? The plugs are already behind the switches so must be connected somewhere. Any ideas or comments would be helpful..cheers!
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you are only fitting the switches, then you would need to make up a link wire to the brown for chassis ground and another for the grey/yellow for illumination.
    if you are fitting the seat heating assembly, then they will illuminate when the seating units have been tech 2 instaled successfully.
    Again if just the switches are being fitted for "effect", then link to the cig lighter illumination connection.
    This will then not affect the canbus system
    Dunstable
    Nice one robsey! Didn't want to have to go joining any wires if there was an easier way of illuminating them, but you've confirmed my question, will get on to it then at some point, just want them to light up for effect, not botherd about wiring heated seat pads or anything...
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    I dont know what spec of Vectra / Siggy that you have, but if you do not have a rear lighter / charge socket in the back of the centre armrest (fitted on design spec and above), then...
    There may be a three pin plug taped up under the covering panel near to the hand-brake...this will have black, brown and grey/yellow wires for the rear lighter / charge socket.
    Just need to connect to this via two male spade connectors (one for each wire that you need obviously)
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by Ademusic View Post
    Mate , they wont work in your SRI, Send them to me i will try them first
    Dunstable
    Quote Originally Posted by spennny View Post
    Thanks spenny, that's very helpful...if only every member was as generous as you are.....
    Blantyre
    No worries mate, always happy to help
  1. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  2. Heated Seat Switches.
    By RBH in forum Parts for sale
    Last Post: 10th November 2008, 14:58
  3. Heated seat switches
    By Baz07 in forum Parts for sale
    Last Post: 13th July 2008, 17:53
  4. heated seat switches
    By j1 wyx in forum Parts for sale
    Last Post: 18th October 2007, 09:53
