Thread: ACC
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Default ACC
    Is it possible to retrofit ACC to a Vectra with the use of a doner car and has anybody done it?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Auto climate control???
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes John sorry figured if anyone had done it they would know what it meant?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    A Little confusing, as it is normally referred to as ECC...Electronic Climate Control.
    It can be done, will take a lot of stripping out the dash,
    Discharging the refridgerant from the aircon.
    Strip out the old air-distribution sytem and electrics and switches.
    Fit donor switches, cabling, distribution unit and also extra wiring for connection to canbus system
    Also extra items like interior sensors, sun sensor etc.
    Refit all the dash components
    Recharge the refridgerant in the air-con system
    And then Tech 2 reprogram the car to its new vehicle "variant" configuration.
    Seen it done in a Vectra B, but then this has no canbus issues.
    If you know exactly what you are doing, then I would allow a whole weekend for this!!
    Depending on your vehicle specs, you may need to exchange modules such as CIM, BCM, UEC and the display (GID or CID only)
    A lot of work...sounds cynical, but would be easier to sell the car and by the spec you want.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Worth the ask but probably not the hastle cheers Robsey
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As what Robsey said. You might need the help of the wiring diagrams that come with something like TIS (if you have access ;-) ) so you get everything you need
    Would be a LOT of work though.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The car I have is already highly speced and has CDC40 with GID, AFL, park pilot front and rear auto dim mirror auto lights and auto wipers factory bluetooth just not ECC and my mates just bought an elite and it was just a maybe with andymagee breaking the signum with all the bits in it still never mind.
