Thread: What moniters flow on the CDTi EGR?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default What moniters flow on the CDTi EGR?
    Is it just a calculation from the MAF (less air as the EGR opens) or does it have its own sensor and if so what type and where?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It will be highly unlikely to have a dedicated flow sensor in the EGR. There is probably a position feedback sensor that probably isn't very accurate. MAF reduction would probably be there too.
    Difficult to say, as there are a few possibilities, but no definites unless you know how the programming has been done.... and I am sure that the calibration Engineers won't be easy to contact....
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Ste View Post
    Cheers for the reply Ste, It was actually a post by you last year that mentioned The MAF may in some way monitor EGR flow. The reason I ask is all this EGR and Manifold faults that come with the CDTi. On the Petrol 2.2 you can just blank but keep the EGR in the loom as the only monitoring is that the valve is open or shut. So it got me thinking, its been mentioned that the CDTi EGR is monitored via flow, if you could return the EGR gases into the exhaust instead of the inlet this would help solve a problem, you will still get the flow so should stop any limp mode.
    On the 3.0 if its blanked completly then it goes into limp home mode due to lack of flow, so it must be measured somewhere
  1. Idle air flow - CDTi 150
    By cont1204 in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 18:05
  2. air flow meter
    By bulldogblu in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 12:44
  3. air flow meter
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th October 2008, 19:42
  4. Shocking air flow!
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2007, 20:18
  5. Hi flow cat or MANIFOLD...CDTi
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 22:24
