Thread: EGR cleaning on 1.9cdti 120
    Oct 2009
    N.Ireland
    Default EGR cleaning on 1.9cdti 120
    Have a day off tomorro and i thought i would spend it cleaning the egr valve on my cdti 120, car has 74k on it and the valve isnt causing so should i still go ahead and give it a clean? Does anyone have a guide to cleaning one on a 120bhp? Iv only ever een guides on the 150.
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Just follow the guide for the 150. Removal is slightly different (but pretty much common sense), cleaning is exactly the same.
    Regular Member tracer's Avatar
    elgin
    i found it kinda akward to remove the egr on the 120. nothing that put me off doing it, just need to take yer time a wee bit. especially on the allen bolts on the underside.
    get a couple of gaskets prior to doing the job also. mine were pretty bad, the thread of the bolts had chewed them a bit so i took a walk to local stealers to pick up some new ones.
    for the sake of a couple of quid get some beforehand.
    if theres no problem with it then its really up to you if its worth doing a preventative clean or not.
    just my 2p
    Jul 2009
    Wiltshire, UK
    Yep, those bolts on the underside are a right ******* to get off!
  1. Issues after cleaning EGR 1.9CDTI
    By Dave_G in forum Engine & Drivetrain
    Last Post: 9th December 2012, 14:18
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. Cleaning Boost Sensor, 1.9CDTi ????
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 23:11
  4. 1.9cdti EGR cleaning
    By darko2301 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 15:45
