Results 1 to 10 of 13
Thread: EGR removal
    Kingston Upon Hull
    Default EGR removal
    Hi all i keep reading on here about EGR getting clogged etc
    So my question is why cant it be removed ?
    if its because it is connected to the ecu why cant you leave the motor connected and just fasten it out the way then plate over the hole where the erg was fitted
    Graham
    Full Member Big Sig's Avatar
    IIRC it looks for a flow, not just that its there, although it depends on engine.
    Kingston Upon Hull
    Sorry its a cdti 150 derv burner
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I wonder how it actually senses the flow and could it be fooled? The 2.2 petrol can just be blanked, you keep the EGR in the loom still cos all it monitors is the actuation of the valve not the flow. Now if the CDTi monitors flow, and as we know you can reduce the flow by fitting a gasket then there is some tolerance. So lets just say you could take it out of the intake system and blank the intake and put it into the zorst system via a T piece and then back into the zorst, it would still get flow of the same hot gasses, I wonder................................
    Kingston Upon Hull
    I have just been told by a AA man they are provided with a blanking plate to fit on saab's they just clean the egr with a spray and fit the plate he says on holes in the plate
    + another person has told me to remove the egr fit a plate then spacers then the egr back on but you need longer studs and bolts
    The spacers let the egr work as normal
    Kingston Upon Hull
    Quote Originally Posted by jacko52 View Post
    PS I DONT NOW IF THESE WILL WORK ITS ONLY WHAT I HAVE BEEN TOLD
    Jacko
    I see a plan forming
    Kingston Upon Hull
    How dose it monitor flow ? i thought it was just a valve or dose it work on heat from the engine exhust gas? that makes it open and close
    Jacko
    Vehicle : SRi
    Mileage : 137000
    Dont know mate, maybe like the MAF does. My 2.2 petrol is blanked but the ECU only monitors the movement of the EGR, so its still plugged in but not mechanically. The CDTi works differently. I have the same CDTi engine in the Mrs Punto, but badged as a JTD, I might have a play with my Idea at some time, but to do it on the cheap all I would have to do is blank the hole where the EGR goes back into the intake and add some tubing to the rear and vent it to atmosphere. Of course this would only be a test but it is deffo a possibility.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    the egr measures flow in conjunction with the air mass meter basically that monitors how much air passes through and if there is no flow from the egr there is not enough air if its too much then there is too much air have a read of this this will explain
    so the answer is no we cant block off the egr valve on the cdti 150 unless you can disable it with tech 2
    http://www.ms-motor-service.com/xima...099_en_web.pdf
  1. dpf removal
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 10:53
  2. Tar removal
    By Jim Bob in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 20:18
  3. Cat removal & EGR
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 16:58
  4. DPF removal
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 17:01
  5. Tow Bar Removal
    By korlinski in forum Bodywork & Interior
    Last Post: 30th April 2007, 21:19
egr disable tech 2 z22se
egr remap z22se
