Results 1 to 10 of 20
Thread: Help needed to convert 12v to 6v
    Sep 2009
    Default Help needed to convert 12v to 6v
    does any one know how i could convert 12v to 6v.
    i bought i car horn not realizing it runs on 6volts not 12 volts.
    anyone know how i could convert the car 12v to 6v to power this ?
    Dee
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Buy another horn and put the 2 in series, especially if you can get a 2nd one with a different tone/frequency.
    or
    what current does the horn take?
    If about 2 amp's or 12 Watt's (at 6VDC) then put a 21W indicator bulb in series with it.
    Regular Member graham a's Avatar
    hull
    Sep 2009
    the horns got a small modulator with it, it can play 18 different tones.
    Sep 2009
    Quote Originally Posted by TonyP2020 View Post
    ........put a 21W indicator bulb in series with it.
    to do this, your saying but the bulb in series before the horn ?
    so it would be...
    battary + ... bulb... bulb.... then horn... then back tothe battery -terminal ??
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Dont really see much point in having a horn that plays 18 different tunes
    cambs
    Quote Originally Posted by daviek View Post
    his radio could be broken
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    It would be battery + then bulb.... then horn... then back to the battery -terminal ??
    Do the instructions say how much current it takes or what size is the fuse on/in it??
    It is also important to know is it requires a perminent Live supply as well.
    Perhaps a link to a website??
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The bulb will work until it blows and then no horn, yes you know to replace it but a simpler solution would be if you brought 2 resistors from Maplins at 2 kilo ohms each it will give a current flow of approx 3 amps and simply tap off from the centre tap and the grounded side. All the electronics can be enclosed in a small plastic enclosure.
    Sep 2009
    nice one guys.
    no real instuctions or power readings just say 6v power supply thats all.
    its got a perminant +power supply and negative, then a blue wire which it says connect to the horn button on the steering..... ( im guessing that is also a + terminal ?? )
  1. possible convert
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 19:52
  2. Hello from a convert again
    By WilliamLX in forum Introduce yourself.
    Last Post: 26th August 2010, 09:57
  3. A new VX Convert
    By Kapt Kaos in forum Introduce yourself.
    Last Post: 11th May 2009, 21:00
  4. Convert!
    By rogerp in forum Introduce yourself.
    Last Post: 30th April 2009, 17:49
  5. LR Convert
    By harveyg77 in forum Introduce yourself.
    Last Post: 29th July 2007, 00:21
