Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: EGR Wanted for 2.0DTI
    Regular Member eaglepva's Avatar
    Up North
    Default EGR Wanted for 2.0DTI
    Hi anybody got a EGR valve for a 2.0DTI, think mine is on its way out so looking for a replacment.
    Sheffield
    This is what I got last year for my 2.0DTI 04, had no problems since, really easy to fit also.
    http://cgi.ebay.co.uk/Vauxhall-Astra...item35a64673a0
    Up North
    Thats the one i going to order if cant find another one. What was the symptoms of your EGR valve problem. My car sometimes, cuts out when coming to a stop at junctions or traffic lights, and the revs start bouncing up and down. I think its either the EGR or the MAF.
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    The EGR went on my 2.2 DTi and the spanner light kept comming on and engine went into limp mode.
    Tech2 at work confirmed it was the EGR throwing up the fault codes.
    VX wanted about £265 plus vat and they were out of stock so sourced one from a breakers with 3 month warranty for £50.
    Took 10 mins to fit and I have had no problems since. Approx 10k miles covered on the second hand unit.
    I would recomend getting a tech2 diagnostic to pin point the fault as my car never stalled etc otherwise you could spend £212 ++++ and still have the fault.
    All the best
    Jon
    Regular Member Dazzy2006's Avatar
    Notts
    Have to agree, when my egr went i also got the spanner light,limp home and accelaration was reduced, best to get the codes read 1st because egr's aint cheap.
    Sheffield
    Mine always flashed the EML and went into limp mode on the motorway, I did get it Tec2'd. And if i can recall it was a P0400 Exhaust Gas Recirculation Flow Malfunction. Got the same even after I cleaned it. Prob gone after replacement with the one from Vauxcentre.
    Check Big Sig's thread on this, http://www.vectra-c.com/forum/showth...ht=error+codes
    Good luck
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds alot more like the MAF if the revs are bouncing up and down, get the codes read
    Edinburgh
    Wouldn't pay for a Tech2 to read the codes ever. Cheaper buying a code reader from Argos/Ebay/where-ever and doing it yourself. It pays for itself the first time you use it and you even get to keep it to use again!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Big Knox View Post
    Problem is that very few cheap code readers work with the dti, I used one that cost 70 quid and it still didn't work
    Up North
    Ive had the car on op-com twice and it comes up with no fault codes. So sort of stuck.
    Done it again today was parked in a garage, got in the car started, revs started bouncing and car jugging gave it a bit of a rev still doing it reversed out the garage, having to keep my foot on the accelerator or the car would nearly stall. Cleaned the EGR and inlet manifold on saturday. Been ok untill today then started doing it seems to do it more when the car has got to running tempriture.
  1. Mpg 2.0dti
    By thestaffy in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2012, 12:22
  2. vec c 2.0dti sxi
    By mgp in forum Introduce yourself.
    Last Post: 26th October 2009, 19:13
  3. Help - can anyone with a 2.0DTi help?
    By evsy72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2007, 14:54
  4. 2.0dti
    By thestaffy in forum Diesel Engine related
    Last Post: 17th March 2007, 14:22
