Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: signum 2.2 dti
    Jan 2010
    warwickshire
    Unhappy signum 2.2 dti
    Hi all
    Just a quicky to say hi to everyone.... being a newbie......
    I have joined because i own a 2003 vauxhall signum 2.2 dti.
    Ive just brought the car 5 weeks ago and had nothing but problems with it... the dreaded spanner light ... had it plugged in to tech2 and it found two faults which were acelerator pedal and what looks like a vacuum pump or solonoid.... anyway both have been changed with new parts but the car still has the dreaded spanner light come on when it feels like it and the car cuts out imediately...the cars been in different garages and run a bill of around £500.00 so far... the cars in great condition but its starting to do my head in.... any help would be great as vauxhall dont have a clue.... there clutching straws ! thanks all
    Nottinghamshire
    Someone should be along soon who has had a similar problem or happens to know what this might be.
    Do you have the fault code numbers (or their descriptions) that have been found? If so, post them here.
    If not, start asking for them whenever you get fault codes read, as people here can generally help a lot more if they know what the actual codes are.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    AS james has said the fault codes are a big help , if you can go back to the garage and find out what fault codes were generated we should be able to steer you in the right direction. in the meen time check all your vacuum hose connection,s , your intercooler hoses for splits or signs of perishing , and check all the connection,s are the right way around.
    Jan 2010
    warwickshire
    Exclamation vauxhall signum 2.2 dti fault codes
    Hi all ,
    Vauxhall found the following....
    trouble codes p0638 electronic throttle sensor high input and p1590 vacuum solenoid valve circuit open both stored not present and cleared down....
    both these parts were changed but i still have the problem.
    Had it rechecked and only the fault code p0638 is showing..
    Ive checked the vacuum pipes .... pondering the alternater ? too mutch charge triping ecu ?
    im lost !!!!
    gratefull for anyhelp what so ever...
    do these have a throttle body with the float or butterfly ? if so it could be sticking.... seems to only happen at low revs ( spanner light and cuts out )
    thanks all
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    hello mate , firstly welcome and second is there a trend to when the spanner comes on? for example certain gear ?
    Jan 2010
    warwickshire
    hi , its mainly when pulling away but has gone on tick over.... i think you could drive the car all day if its doing over 30mph ... it always seems to go when your in low gears.. ie .. pulling away....tick over... and mainly when your pulling out of junctions... i'd prefer a rollercoaster ride than to drive it... its getting dangerously scary.... makes it worse because ive got two young daughters who travel in it with me.... love the car just hate the problem....
    Jun 2009
    Newcastle
    ah well not the problem ive had , mines only if i go in fifth early , hope it gets sorted soon mate
    Jan 2010
    warwickshire
    The signums booked in again at vauxhall on Tuesday so fingers crossed they find the fault as i cant aford to keep it much longer..... this will be the 6th time its gone in !Hopefully its something silly but i wouldnt care if its the ecu as long as the faults found and 100 % rectified.... will keep you updated but i dont have much hope lol
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Could it be a Faulty throttle body ? sometimes these get caked up might be best getting it cleaned first to see if it solves it
    Irmscher Insignia CDTI 130
    Regular Member muzmayhem's Avatar
    Jan 2010
    North Angus, Scotland
    Oh my god! I've just bought a 2003 Signum 2.2 DTi Elegance yesterday. What am I letting myself in for!
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
Trubel code p1590 2.2 vectra 2003
