Results 1 to 10 of 19
Thread: The siggy ,s playing up
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default The siggy ,s playing up
    The siggy has just started playing up , on tick over the revs are constantly dropping and resurging back to normal tick over , this has happened a couple of times in the recent past but usued to clear after a blip of the throttle now it is constant , could not see to do too much tonight but i did disconnect the electric connection of the maf surprise surprise tick over returned to normal.
    now does the problem lye with the maf going t/u or is the problem somewhere else
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I have a similar problem to this Bob, when I start the car first thing, after about a minute the revs start to fluctuate up and down by about 150RPM.
    After another minute or so it seems to clear itself
    Engine : 2.0DTi
    Mileage : 73350
    While i was posting the original thread i had left the engine running with the maf electrical connector detatched just been out there again reconnected it and lo and behold she runs normally , so has anyone got any ideas on this .
    john your problem sounds like a lazy temperature sensor but not certain,does any body else have any experiances in this deptartment .
    Engine : 2.0DTi
    Mileage : 73350
    bump ty bump
    Engine : 2.0DTi
    Mileage : 73350
    what has nobody had this problem before?.
    Engine : 2.0DTi
    Mileage : 73350
    Just had a recurrence of this problem again over the weekend , it does not seem to hold to any pattern ie it can play up when engine is cold or hot . what is ocuring is the butterfly in the manifold is closing and opening of its own accord causing the engine to breifly stall . anyone else come across this as i thought this had been cured once.
    Could be time to move on Mr Bob ................... ......................
    Engine : 2.0DTi
    Mileage : 73350
    Its just weird terry the previous two weekend,s traveled up to silverstone and back , no problem at all , started hicuping coming back from shawbury on thursday and has been almost constant since but as said before there is no pattern to it .
    This is the best place for help Mr Bob as you know
    Someone will be along soon to advise you the best plan of attack ............
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I had a similar issue but mine cleared touch wood with some switch cleaner on the MAF lead connector
  1. 2.2 dti playing up now
    By fattony in forum Engine & Drivetrain
    Last Post: 17th October 2010, 21:16
  2. been playing
    By don paul in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:15
  3. just been playing with my wii!!!!
    By BIG NEIL in forum Games Room
    Last Post: 15th September 2008, 14:24
  4. been playing
    By PeteRs in forum The 'Off Topic' room
    Last Post: 11th February 2008, 15:54
