Thread: Nearside/offside help.
    Sep 2009
    Glasgow
    Default Nearside/offside help.
    Just want to confirm i have fitted my sensors correctly. I have fitted them a-b-c-d from lefthandside passanger side (offside)2 righthandside drivers side (nearside).
    Nottinghamshire
    Isn't the passenger side called the nearside, and the driver side called the offside?
    Regular Member Steevo's Avatar
    kent
    Nearside is nearest the curb. (passenger side)
    Sep 2009
    Glasgow
    so i have fitted them ns too offside a-b-c-d had a look at the manual and thats the way they are pictured, the how 2 says fit them os too ns. Is there any problems with fitting the wrong way aslong as the follow order.
    Nottinghamshire
    Quote Originally Posted by nokiaman1978 View Post
    Each sensor should be connected to the correct port on the controller module as per the instructions.
    As to whether the nearside/offside matters, I suppose it may depend on the kit you have fitted. If it's just one that beeps based on the distance to the nearest object (regardless of whichever sensor picks it up) then it may not matter which way round they are.
    But if it's a kit with a screen that shows you the distance of obstacles from each sensor then it may show everything reversed between left and right.
    Sep 2009
    Glasgow
    cheers thats the info i was looking for the guy that did the how 2 must have had screen thats why he was specific about sensor flow.
    Sep 2009
    Glasgow
    will post pics tommorrow.
  1. nearside upper & offside lower brake lights
    By panos9 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2011, 15:51
  2. MOT Failure - Offside Handbrake
    By sriturbo in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2009, 15:53
